Nose gear strearing
Hi All
I have a couple of questions.
I'm biulding a 40 trainer with a OS .46 FX motor.
I'm useing goldenrod for all my control surfaces, can I use it to control the nose gear strearing realizing how flexble it is. Also can I mount the motor using nylok nuts instead of using washers and steel nuts The motor is mounted to a radial motor mount, will the motor get too hot and melt the nylon part of the nut.
