RE: GasZenoah 26 engine in plane causing rf glitching HELP!!!
Do you have any long servo leads? Are they running parallel to the antenna? Have you tried moving your antenna around. I had some issues once that were corrected by moving the antenna away from long leads running to the rear mounted servos. Just thought I'd throw that out.
