RCU Forums - View Single Post - LT-40 taildragger conversion DONE !
Thread
06-24-2004 | 01:32 PM
28
abufletcher
Feb 2004
15,019
1 Post
Zentsuji, JAPAN
RE: LT-40 taildragger conversion DONE !
Well, you guys motivated me to do that taildragger conversion I had been talking about every since I bought my trainer! Since I'm currently building an Eindecker III as a second plane I thought I'd get a little taildragger experience first.
It was definitely a guerilla conversion and she sure ain't pretty but then who cares what a trainer looks like! First I tore out the bottom balsa and seated a 1/4" ply piece into the fuse walls. Then I drilled and tapped (and thin CA's) the holes for the DuBro main gear. Then covered the construction with that stick on covering tape. Next the tail gear: Epoxied and screwed on a Sullivan tail wheel assembly. I thought about having it freely rotate but that wouldn't be like my Eindecker so I opted to guerilla attach the wheel to the rudder via an extended wire. This meant cutting out a little V in the rudder. No problem.
Anyway, I think my little RCM trainer now looks a bit like a Cub. Heck, who knows, maybe I'll get REALLY motivated an recover it in Yellow (since most of the original covering is peeling off anyway) and ad some wing struts for show!!
Reply
Like
abufletcher
View Public Profile
Send a private message to abufletcher
Find More Posts by abufletcher
View iTrader Profile
