RCU Forums - View Single Post - GSP 65" Extra
Old 06-24-2004 | 02:27 PM
  #43
GasRookie
Default RE: GSP 65" Extra
ORIGINAL: tIANci
If you plane snaps when you pull the elevator then there might be too much throw or its just that the plane has bad flying characteristic. Try to put in some EXPO (30%-40%) and tame the plane down by making it a little nose heavy until you are used with the plane. Also try adding some washout on the ailerons ... 1/8". Try and then see ... also ... loops faster to try and eliminate the tip stall. Happy huntin'
it has a lot of expo the throw is not to much a friend with good touch flew it and noticed when its looped fast its ok but slow loops it snaps and trys to snap in just regaler flying we checked everything im ready to sell in i cant handle it
