Phoenix 10 programming for Shocky
I'm new to electric (fly IMAC normally) and am putting together a Shock Flyer (one Edge and one Extra). My setup is:
Phx 10
Axi2208/34
APC 10x4.7
Hitec Feather
HS-50's
2-cell 700mAh Lipo
I'm looking at the speed control and have no idea what settings to use (or that so many settings were possible!!!). So, my questions are:
1. Low voltage cutoff - the directions say to use 5V for a 2-cell Lipo... I didn't think you were supposed to go below 3V per cell???
2. Current limiting? Leave as standard?
3. Brake type... which to use?
4. Throttle type: I'm assuming Auto Calibrating???
5. Electronic timing advance - I'm using an Axi 2208/34 with a 10x4.7 prop... what to use?
6. Cuttoff type???
7. Soft start???? Do I use this with a direct drive?
Anything else I should know? Important mods to make? What control throws work well?
Sorry so long winded... I'm pretty e-dumb.
Cheers!
Jason
