RCU Forums - View Single Post - The dreaded flat spin
Old 06-25-2004 | 12:13 AM
RickAvery
Default RE: The dreaded flat spin
Mikerjf,
I can't say that the dozen or so times she was put into a flat spin, that it was done on purpose. Nor can I say that each time she pulled out, that it was from anything I deliberately did. Each time it spun out, it became less threatening as the recoveries were repeated. The sequence 'let go of the stick. Throttle off, throttle on', seemed to work in several spins. Didn't work this time. The sky scooter has no rudder. Ailerons, elevator & throttle. I think a rudder would be helpful. Soooooo, Until I figure out a reliable sequence or procedure, I'm afraid they'll be a bit dreaded. The learning curve/challenge is half the fun. Thanks all, for the insight and comments.
Rick
