ORIGINAL: TNRabbit
How is the line going to the filler sealed? Is it a fuel dot? Easy fueler? I seriously doubt the tank position would prevent it from starting, but the centerline of the carb should be aligned with the center of the tank or pretty close to prevent problems during flight. If you close the carb down to a high idle and put your finger over the carb while turning the prop (WTHOUT glow starter attached!), it should draw fuel into the carb fine.
Are you using an electric starter or chicken stick? Has the engine been broken in yet?
The filler line is plugged with the silver fuel plugs.. Dont know the exact name of it. If I close the carb and prime it, then take my finger off, fuel will come out of the carb (the motor is mounted inverted).
Chicken stick. The engine has been started before, but not exactly broke it.. Its been ran for about 5 minutes.. I just find it weird it would start with one gas tank and not the other
