Replacing Crystals
I have the opportunity to get an extra receiver, it is on the wrong channel but I don’t see that as a major problem – Just replace the Crystal with the one that I need.
However; I am on channel 58 and the receiver is on channel 32, a local expert has told me that the Airtronics receivers can only have the Crystals replaced in certain bandwidths, ie low end or high end.. If you attempt to put a High end Crystal in a Low end receiver it will not work and vice versa…
Can anyone comment???
