RCU Forums - View Single Post - The dreaded flat spin
Old 06-25-2004 | 08:37 AM
RickAvery
Default RE: The dreaded flat spin
Matt,
I've been checking out the ads on the space scooter. I've also been talking to Mike at Hi Tech about it, (he says they are currently flying and testing it). In the ads, it mentions two servos, and Mike @ H.T. assured me that it will have ailerons. I have to assume that it will be without a rudder. The thinner, semi symmetrical wing is is being advertised as being interchangable with the sky scooter fuse. I'm looking to pick one up as soon as they are avaliable. I will check my CoG on my scooter. I have two dots I placed under the wing at 4.5" from the leading edge root. It has always balanced out fine, but, I was using a new batt-pack with a square configuration instead of the OEM flat pack. So I may need to slide it as far forward as possible to at least give it chance to recover. Here are a couple of links about the space scooter. What's in the ads, and what I'm being told by Hi Tech are a little conflicting.
http://www.modelspot.com/mpx/scooter.htm
www.multiplexusa.com
Rick
