RE: Replacing Crystals
As Geistware stated, ONLY Futaba specifies high/low range (11-35, 36-60). If you move more than 3 or 4 channels it is a good idea to send the receiver in and have it recalibrated. The receiver will work as is with the new crystal, BUT, your range MAY be reduced. I suggest putting the new crystal in and do a range check. Then go from there.
