RE: Rustler Wheelies?
You can't really make the Pro 15 Rustler do wheelies, it just doesn't have enough power. Pretty much the only way to do wheelies is if you lean it A LOT, so much that it would mess up your engine. I have a Pro 15 Rustler, but I got a Fantom .12 engine and an Associated low end pipe for it. I can't pop wheelies on asphalt 'cause my street tires are too worn, but I pop wheelies on dirt all over the place when I don't even mean to. For dirt, I use Edges on the front and Step Pins on the back.
