RCU Forums - View Single Post - questions about differnet Models of Toger Moth
Old 06-26-2004 | 08:26 AM
kwiktsi
Default RE: questions about differnet Models of Toger Moth
I honestly don't remember which one mine is. My LHS has another one there, so I will try to get the part number today while I am there. For my ESC, I am using the Pixie 7 Castle controller.
Joe
PS- the only "mod" that had to be done with the dual motor setup is to rotate the motor stick 90 degrees so that the motors fit under the cowl properly. My friend said he didn't have to, but mine would hit. Since mine was glued in so well, instead of pulling it, I shaved it narrower glued a thin strip of wood to the top to make it the same as if I had twisted it. You will see what I mean if/when you get it. Simple install though.
ORIGINAL: rand256
Kwiktsi,
I have looked at a few of the twin motor ips, there are several versions. I cant find my instuctions and was wondering what all the different models where for and which one yoou have. Alos in terms of your ESC. I am using the GWS ICS50 , 2 amps 4-8 cells. I am definately going out this week end and see if i can track down a 700-800 mah ni-cad.
Can't wait to get up in the air again soon.
See ya......................Jim
