RCU Forums - View Single Post - BME-44 backfiring (FIXED)
Old 06-26-2004 | 08:47 AM
Antique's Avatar
Antique
Default RE: BME-44 backfiring
Had the same problem on one of my gassers, it turned out to be the ignition battery. Was using an old 4.8 volt flight pack. It would test OK with an ESV that had a 200ma load. Tested it with a 500ma load and it failed, voltage quickly dropped to 3.9 volts. Changed battery packs, problem solved.
