ORIGINAL: phat742
i ran into a problem and i was wondering if it is a big deal. the instructions say to mount the engine so that the back of the spinner is 5" in front of the firewall. i can only get 4 7/8" with the engine all the way to the front of the motor mount. is this ok or do i need to get a longer motor mount?
Hey phat, i have this same engine, and have also ran into the same problem, did you try mounting the cowl further back? Did it work ok? Or did you get longer engine mounts?
Awaiting your answer as i am at this stage now, cheers m8.
