RE: Wash out, where to pivot this angle?
Ah, I see.
OK but it's still all relative. Depending on how you cut and join the center section joint the washout may appear to be relative to whatever points are in a straight line through the whole wing. And if you use more dihedral than that then there won't really be any firm reference line anyway. As long as your twist angle from root to tip is good then you're fine.
