Little Toni Firewall Issue
Hi,
I have a GP Little Toni with a OS 91 FS. I have about a dozen flights on the plane and I really like it. But, I found an interesting problem. I can move the engine up and down about 1/8 inch. All my screws are tight between the mount and the firewall. The mount has no crack and the prop is balanced. What I found is the fiberglass front end buckles slightly when I move the engine up and down. The plywood mount is solid on the back end of the fiberglass and I see no cracks on the outside. I've email GP and awaiting their answer.
But, I'm wondering has anyone else seen this problem? Also, should I worry about it? Any suggestions to fix it from the inside?
Dave
