RCU Forums - View Single Post - Real Flight G2 - what does third switch do?
Old 06-27-2004 | 11:59 PM
iflynething
Default RE: Real Flight G2 - what does third switch do?
As you can see, you have one person that uses it for idleup and the other for dual rate.
I will tell you that right when I got the sim, I flew the heli, and flipped the switch, that is throttle hold. Well, that is what it is on mine, I dont' know about others. But you can really set it up any way you want it.
I didn't even think about it as being idle up and normal being it only 2 postitions....Like I said, when I first got the sim, the idle up was on the left switch when it is in the middle position and normal for all the way up or all the way down......
I think that I might have to switch the idle up from the left to the right.....
