RCU Forums - View Single Post - Four-stroke manifolds
Old 06-28-2004 | 12:09 PM
cu. in.
Default RE: Four-stroke manifolds
Hi Engineman,
I read your post several times and don't know exactly why you posted to the "Engine Conversions" forum. I am guessing you are suggesting that four stroke engines don't require a Walbro style pumper carb to meet fuel draw requirements. It appears that you have had some success testing your own machined manifolds that place the carb at cylinder head level.
I have a few questions. First, were these engines that you converted operated on glow or spark ignition? Second, did you notice a drop in RPM with the shorter, straight manifold. The reason that I ask this question is because I wondered if there was a slight tuning effect derived from the long intake pipe found on the Asian four strokes. Third, if you operated the engines on gasoline rather than glow fuel, did you try to insulate the carb from cylinder head heat?
I always liked the direct approach taken by Laser Engines of mounting the carb straight on the head. Perhaps the Laser engines would be a good candidate for conversion to spark ignition, or has Neil already done this?
Bruce
