RCU Forums - View Single Post - Need help with ryobi ignition
Old 06-28-2004 | 03:18 PM
Flypaper 2
Default RE: Need help with ryobi ignition
Yes, Peter, the trigger electronics is built into the coil and the little module cannot override it. You might try running the coil as close to the flywheel as possible without dragging on it to see if that makes a difference, as you get a stronger magnetic field. If it's the RPM that triggers it, then it won't work.
