RCU Forums - View Single Post - Help with yaw control
Old 06-28-2004 | 05:29 PM
Ehud
Default RE: Help with yaw control
Reversing the blades made no appreciable difference, helping to convince
me that the speed is too low.
I then bumped up the speed to 80% throttle (problem here, see below)
and at that point right rudder indeed caused a little yaw to the left.
I've got my rotor blade pitched mixed with throttle such that from
50% throttle to 100% throttle it goes from 0deg pitch to 12deg pitch.
I suspect that may be too agressive, as I'm taking off before I have
full rudder control.
What do you guys use for a throttle/blade pitch mix line/curve?
Ehud
