RCU Forums - View Single Post - Simple glowplug-question
Old 06-29-2004 | 07:51 AM
Cogburn's Avatar
Cogburn
Default RE: Simple glowplug-question
There are basically two different glowplugs. Short and long. There are variations in these types for specific engines; with or without idle bar, 4-stroke, different heat ranges, etc. Most Sport type 2 stroke engines use a standard long idle bar glow plug. Your engine's instructions will state what length plug it requires. Then you try the plugs you have available of that type to see if they work good in it. Godd luck!
