RCU Forums - View Single Post - Balancing ARF in longitudinal axis
Old 07-13-2002 | 12:36 PM
Elwood
Default Balancing ARF in longitudinal axis
Add helium to the heavy wing. Works every time!
You could cut a small hole in the tip, coat some lead fishing weights in Epoxy, and drop it into the hole. Make sure they get attached to some wood. Then use a small patch. This might be better than the helium idea, but you never know!
