RCU Forums - View Single Post - Balancing ARF in longitudinal axis
Old 07-14-2002 | 03:02 AM
Hanger Rat
Default Balancing ARF in longitudinal axis
Re the lead weights. I always shave the lead into small thin pieces befor slipping them into the wing. If you want to add weight without cutting a slit in your covering just use epoxy. You can buy industrial hyperdermic syringes fill it with 30 min epoxy and inject it into the wing at the tip. then stand the wing on its tip till epoxy sets.
