RCU Forums - View Single Post - Balancing ARF in longitudinal axis
Old 07-16-2002 | 03:15 PM
MinnFlyer's Avatar
MinnFlyer
Default Balancing ARF in longitudinal axis
I like the syringe Idea if you don't need too much weight, but a good deal of weight needed could run into $$$ with epoxy. I do the fishing weights (Split Shots) and epoxy. Drop them into a hole in the bottom of the wingtip, then apply a patch of covering or even scotch tape (what the heck, tiny hole on the underside of the wing, who's gonna see it?)
