RE: Elevator CA Hinge Problem
While I don't have a lot of experence with building, I will tell you that if your control is not stiff, then your surface will flutter and this will wear out your hinge. Make sure that the rod connection both sides is stiff and that the control cannot flex. If it is one complete control surface, make sure the control is stiff and will not flex.
