RCU Forums - View Single Post - Vibrating Kyosho Trainer 40 problem
Old 06-29-2004 | 02:18 PM
Campy's Avatar
Campy
Default RE: Vibrating Kyosho Trainer 40 problem
Did you balance the prop ? If you did balance it (or after you balance it) if it still vibrates, try running it without the spinner. Something is out of balance, and the primary culprit is the prop with the secondary culprit being the spinner.
Hope this helps.
