RE: Vibrating Kyosho Trainer 40 problem
My question would be is the back blate of the spinner a tight fit around the crank shaft? Does the spinner come with bushings or do you ream it out to the correct size? Most new porps are close enough to balance that it sould not shake like your is. Sounds like a spinner issue or worse, a bent crank shaft!!![X(]
