RCU Forums - View Single Post - Vibrating Kyosho Trainer 40 problem
Old 06-29-2004 | 07:54 PM
campbec
Default RE: Vibrating Kyosho Trainer 40 problem
Hi Zeno,
Try one thing at a time so you will know what improves the situation. I agree with the others that it is most likely the spinner.
Remove the spinner and try this first. If it still vibrates balance the prop and try again. If it still vibrates after removing the spinner and balancing the prop it sounds like the crankshaft.
Good Luck,
Colin
