RCU Forums - View Single Post - Gas users, what type of receiver are you using?
Old 06-30-2004 | 12:14 AM
Flyfalcons's Avatar
Flyfalcons
Default RE: Gas users, what type of receiver are you using?
I use a PCM receiver and do a range check both with the engine off and with the engine running. If both range checks are satisfactory then I fly just like any other model. If either range check is unsatisfactory then I find the problem and fix it before flying.
