RE: Help with yaw control
Ehud,
I had to set my throttle/tail rotor pitch mixing a little at a time. I also had the same problem with my tail rotor not having enough thrust, and I found the gear that drives the tail rotor was stripped (X-cell pro). I could actuall see the tail rotor blades decrease in rpm when I applied left or right rudder.
Good luck
