ORIGINAL: jimcork1
I have been using the Hitec Supreme, Resistor plug is a must.. No problems. Jim
jimcork1,
Resistor plug?
And about FM or PCM
I'm using a Hitec FM RX in my H9 Extra, it's far enough away from the ign switch, battery and wires and I've had no problems. I had a H9 Sukhoi that was using a PCM RX and I was shot down at Joe Nall, either way you go you will still get hit, the only difference is PCM remembers the last input, well if you are getting hit you are getting hit. Noone has really given me any reason why one is better than then other.
