Clutch Problem ??
I found the problem- this was care of "Mark Fadely"
if you have an older fury it could be the gold lower ring of the constant drive unit slipping. If there are set screws in the sides of that gold ring at the bottom of the split gear assy then you don't have a problem. If there are no set screws then chances are that's your problem. We've had several of the older ones come loose and that's why minair is putting set screws in them now. BTW, most of the clutches will be discolored like you mentioned and not likely that it is the clutch slipping.
Mark Fadely
I'm glad it's not my clutch. But how do i fix it now?
