RCU Forums - View Single Post - Gas users, what type of receiver are you using?
Old 06-30-2004 | 11:31 AM
Darrinc
Default RE: Gas users, what type of receiver are you using?
ORIGINAL: crashland 73
has anyone ever had nothing but interference and just went to pcm and had good luck?
I have a friend that worked for three months trying to get rid of is interference, he finally broke down and went the PCM way and it works. I know that the PCM is just masking the problem.
It was a strange problem though, everything was changed out of the airplane, servo's, wires, batteries, ignition ect... The best idea that we came up with is that he has a tight bearing that is squealing in the RF range. In a few months he will try the PPM reciever again to see if the problem still exists.
