RCU Forums - View Single Post - Differential Aileron
Old 06-30-2004 | 12:07 PM
Kaos Rulz
Default RE: Differential Aileron
Scott,
Set it up as close as you can mechanically, then go to the ATV function in the programming mode for each channel and adjust the down side for correct throw. The same procedure will work for the up function should you need to do so.
Good Luck
