RCU Forums - View Single Post - Beech Stagger Wing - 90 Size, collaborators?
Old 06-30-2004 | 12:58 PM
br549
Default RE: Beech Stagger Wing - 90 Size, collaborators?
Mechanos,
You have brought up some good points. It appears that a .90 sized airplane would be 15% scale. I was looking at the 52-60" span. under 1000 in2. This does not make a round scaling factor. Perhaps I should consider the larger 1/6 scale. The 1/6 scale would require a .120? I found the thread for the StaggerWing building project on IFLYRC. What do you think about the 1/6 scale? Anyone doing fiberglass on the cowl?
Beepee,
I will look at the plans when I get home and post the reply. The plans were drawing by a guy in Madison, WI. I forgot the name and scale. I thought the wing area was in the 2100-2300 in2 range.
Regards,
Bernard
