RE: Ron Daniels Tempest Tips
Hi Josef,
thanks for the reply! I installed the aileron servos as you did but with a hatch. I am now having difficulty getting my glow motor mounted far enough back against the firewall to not have to extend the cowling too much to get up behind the spinner baseplate. Looks like you went electric so probably less of an issue.
I am contemplating moving the firewall backwards a little but have to figure out the change in angle needed for the offset if I do that, not too keen on that. Today I am going to look for an alternative engine mount and hopefully will have some success.
Adam
PS Did you use a hidden internal antenna or a trailing wire? Any more photos would be really appreciated. Thanks. The last two didn't make it!
