RCU Forums - View Single Post - DP 330 Ailerons Quick fix ? FOR fLutter
Old 07-14-2002 | 12:21 PM
rctt
Default DP 330 Ailerons Quick fix ? FOR fLutter
Had an idea to get some opinions on / As we all know on open structures 80-90 % on it's strength comes from the covering /
How would doubling the ultra coat on the bottom of the ailirons strenthen in torsion /Light weight and easy to do / most of us have the extra
covering from sealing hinge lines OR
Useing a fabric type under the ultracoat?
DO You THINK this will strengthen enough ?
IMO less hassle then extra servo install .
Reguardless it is important to keep the covering tight on the ailerons.and check them in hot weather !
Thanks Ron
