RCU Forums - View Single Post - DP 330 Ailerons Quick fix ? FOR fLutter
Old 07-14-2002 | 09:52 PM
Ollie
Default Stiffen Aileron
Here is another thought. Remove the covering. reduce the thickness of the aileron by planing and sanding. Add 1/32 contest balsa sheet to both sides of the aileron. This will stiffen them without adding much weight. Use thin CA to harden the balsa where the horn mounts.
