RCU Forums - View Single Post - Bigger wheels or smaller prop?
Old 07-01-2004 | 02:44 PM
ksechler
Default RE: Bigger wheels or smaller prop?
Over time or with a hard landing or two the landing gear will bend. Check to see if the nosegear is bent backwards a little. If so, bend it forward. It should be perpendicular to the ground. You can make the mains a little taller by bending the legs together some too.
