RCU Forums - View Single Post - Problems with inverted 2 stroke
Old 07-01-2004 | 02:52 PM
ksechler
Default RE: Problems with inverted 2 stroke
You tank is most likely too high. You want the tank at the same height as the carb. If you mount your tank like your used to with an upright or side mounted engine, it will be too high.
