RCU Forums - View Single Post - Edge 540 Problem
Old 07-01-2004 | 06:17 PM
Tired Old Man
Default RE: Edge 540 Problem
Since this idea is considered to be illegal in the U.S. I can't suggest it, but if you were to change the rx and tx crystals you might find the cause. I have seen tx modules start to do some wierd things, and a change in channel number seemed to clear up the problem. Of course if that is the problem, the module should be changed or sent in for retuning.
