RE: Balancing a Mid Wing Plane?
mohawker23rd - yes, I know how to balance and use the level and what the process is. I had the same issues with my Funtana. Just a little either way, and the plane will fall the rest of the way. If you have a high wing or a low wing that is balanced inverted, this problem is not as exaggerated.
