RE: YS .63FZ problems
The key here is that both engines ran fine on the profile at first, then the performance became worse. In our experience, profile aircraft have the tendency to warp the engine crankcase (leaking from the joints in the case), because the nose is not strong enough nor rigid enough to support the engine properly.
I would advise that both engines be sent into service for repair.
