RCU Forums - View Single Post - Lithium Polymer in Profiles successfully tested!
Old 07-02-2004 | 09:10 PM
martyg
My Feedback: (42)
Default RE: Lithium Polymer in Profiles successfully tested!
If these regulators use commodity ICs for their internals, it's safe to assume any extra voltage just gets dissipated as heat. Put another way, whether you are 2S or 3S, a 1200mAh pack will still give you 1200mAh at the output voltage.
Now, if they called these DC-DC converters I would have a different opinion, but those are much more complex (read heavy and expensive) animals than regulators.
Bottom line is its unlikely 2S->3S will do anything except add weight.
