RCU Forums - View Single Post - spars and cg
Thread: spars and cg
Old 07-02-2004 | 10:09 PM
Levi_Jordan's Avatar
Levi_Jordan
My Feedback: (21)
Default RE: spars and cg
If you are using an airfoil, then put the spar on the high point of the wing. This is where all the forces happen, regardless of the CG location.
If you are using a Flat plate wing, then go with 33% MAC for the spar location. It's a good spot for most applications. Wing sweep may be a factor...
