addiction: NOUN: 1a. Compulsive physiological and psychological need for a habit-forming substance:
(1) Tolerance, as defined by either of the following:
a. A need for markedly increased amounts of the substance to achieve intoxication or desired effect.
b. Markedly diminished effect with continued use of the same amount of the substance.
(2) Withdrawal, as manifested by either of the following:
a. The characteristic withdrawal syndrome for the substance
b. The same (or a closely related) substance is taken to relieve or avoid withdrawal symptoms.
(3) The substance is often taken in larger amounts or over a longer period than was intended (loss of control).
(4) There is a persistent desire or unsuccessful efforts to cut down or control substance use (loss of control).
(5) A great deal of time is spent in activities necessary to obtain the substance, use the substance, or recover from its effects (preoccupation).
(6) Important social, occupational, or recreational activities are given up or reduced because of substance use (continuation despite adverse consequences).
(7) The substance use is continued despite knowledge of having a persistent or recurrent financial or marital problems that is likely to have been caused or exacerbated by the substance. (adverse consequences).
Hmm,
Sound familiar?
