Magnum Review (Engine West 50V1)
Isaac, the following is the result of two magnums experience:
- no fuel leak from the front berring
- there is no need of high nitro to get high RPM, infact I 'm using a 5% morgan with one extra oz. of turbine oil per gallon, an APC 9x7 and OS # 8 plug and I'm reading 18,500 on the ground,
my freind EVEN is using an APC 8x9 (the best prop for this plane)
and is well into the 19000 RPM.
- do not cut the pipe, make sure you have 1/8" between the header and the pipe.
Guido
