Max Products Inc. (MPI) on board glow Any one else haveing problems?
I have had two different MX-9900 on board glows in this plane. It will be fine for a while then it will start glitching all of my servo's. Does not matter whether the plane is running or not it usually occurs after at least one flight. It occurred the first time on the ground after three flights while I was doing a flight check for the fourth. Took the plane home moved the receiver and antenna further away from the unit. Flew it four times no problem and on the fifth it did it on take off and liked to have lost the plane but was able the get it down. This time I switched with a new unit and replaced the crystal. Flew it once for about three minutes and put it down, went back to try it again a few minutes later and when I turned it on it went crazy again? Have spoke to MPI and the owner told me that they had had trouble with some set ups but not ones that were set up like mine?
I am extremely wary of this whole set up now? Has anyone else had any problems like this?
CT
