RCU Forums - View Single Post - 9C dual elevator servo programming???
Old 07-03-2004 | 07:31 AM
Stick Jammer
Default RE: 9C dual elevator servo programming???
Just an added note, be sure to set the two aileron travel settings to zero in the ailevator function window if you want the elevators to work only as elevators. Otherwise the elevators will function as ailerons when the aileron stick is moved.
