RCU Forums - View Single Post - DA-100 Mid Range
Old 07-03-2004 | 03:23 PM
JB Rekit's Avatar
JB Rekit
Default RE: DA-100 Mid Range
I agree. Put the low end needle right at the point to where it sags a little after start up b.c after the engine gets warmed up you will have a great transition and if you high end is just to the rich side of peak, you shouldn't have any midrange problems. When you tune the high end, do it after the engine is heated up, if not you will more likely be making it too rich.
